Version: Thingworx 7.1.1
I want to get the ConfigurationTable of a custom Authenticator via a service of a Thing. I need to retrieve a configuration property.
To demonstrate, I am using the ThingworxMobileAuthorizationAuthenticator. The behaviour is the same as for the custom Authenticator.
Using Postman works fine, but when I try to code it using the Entities tab in the Service script, like so:
I get this error when I test it:
What does this mean?
Thank you,
Shane
Hi Shane Clifford,
Attached is the export of Authenticators_ThingworxMobileTokenAuthenticator from my instance 7.2.3 and there is no configuration table for it.
Does your custom Authenticator have a Configuration Table?
Also, could please share more details about your custom Authenticator and how it works with postman.
Ankit Gupta
Hi Ankit Gupta,
Thanks for your reply. Copy and pasted the wrong Authenticator name
I meant ThingworxMobileAuthorizationAuthenticator, which has a configuration table named AuthenticatorConfiguration.
Here's the Postman request:
POST /Thingworx/Authenticators/ThingworxMobileAuthorizationAuthenticator/Services/GetConfigurationTable HTTP/1.1
Host: localhost:8081
appKey: <my_app_key>
Content-Type: application/json
Accept: application/json
Cache-Control: no-cache
Postman-Token: c4df65fa-f5f6-6cca-380c-dc578c00ab4a
"tableName": "AuthenticatorConfiguration"
And here's the response:
"dataShape": {
"fieldDefinitions": {
"tokenLifeTime": {
"name": "tokenLifeTime",
"description": "Token LifeTime",
"baseType": "LONG",
"ordinal": 0,
"aspects": {}
"generateTokens": {
"name": "generateTokens",
"description": "Return generated tokens",
"baseType": "BOOLEAN",
"ordinal": 0,
"aspects": {}
"rows": [
"tokenLifeTime": 2592000,
"generateTokens": true
Now, trying the following in a Service script:
var params = {
tableName: "AuthenticatorConfiguration" /* STRING */
// result: INFOTABLE
var result = Authenticators["ThingworxMobileAuthorizationAuthenticator"].GetConfigurationTable(params);
Returns:
Error executing service
ReferenceError: "Authenticators" is not defined. (getConfigTable#6)
Details of our custom authenticator (which works successfully) isn't needed here, as the error received is precisely the same for the Thingworx Authenticator.
The custom authenticator stores a value in its configuration table during authorisation. Once logged into the instance, we need to a service that will read the property from our Authenticators configuration table.
Why does Thingworx Composer provide Authenticators under the Entities tab for coding a Script of a Service, and then throw a ReferenceError saying "Authenticators" is not defined... seems like a bug?
Thank you,
Shane
