Hi experts , I'm beginner about thingworx.
I'm Korean so I am poor at English.
I want to know snippets.
I don't wonder definition of snippet. How it is used and What do I use it for thing?
I hope a simple exercise.
Thank you.
Hello! A "snippet" in English generally refers to a short, quotable section of text. It's become used in the digital world to mean that you cut a little useful bit of video, text, or code from something larger. Hopefully that general description helps give you some context.
In ThingWorx, a "snippet" is a small bit of reuseable code that you can use to build a service. ThingWorx provides many of these useful bits of code (snippets) that can be combined together to accomplish tasks for your Things.
This Guide might be helpful for you to see how snippets can be used: https://developer.thingworx.com/resources/guides/application-development-tools-tips-tricks
oh thank you! I'll practice with the guide
thank you! I'll practice well the guide
(in Thingworx) A 'Snippet' is just sample code that PTC has already written for you. If there are any input parameters for the code, it will leave them 'undefined' so you can fill them in yourself.
thank you for your reply!
