What is wrong with the script?
tguo
I use postgreSQL to extract data as a datashape from the database. Everything seems OK. The columns from database are shown as follows:
But when I write SQL script "select * from LiftStatus", Error happen
What is the problem?
Thanks!
supandey
(To:tguo)
Hi Tiantian, just to confirm did you save the Entity before testing the service?
tguo
(To:supandey)
Hi Sushant,
     I have saved Entity before testing the service.
     I also test the thingworx database and another imported database, they are all good in Thing->Services.
     I am thinking if there is special requirements in the tablespace the database lying in? Or something else? I am still trying.
tguo
(To:supandey)
Solved. I use pgAdmin III to construct database. So the sql script need to use "", like select * from "TableName".
Finally...
