When attempting to re-import the license file, the process completes with the status 'Ignored'
DS_14456119
I am using ThingWorx Platform Release 9.1 and DatecodeN/A
When attempting to re-import the license file, the process completes with the status 'Ignored' instead of 'Successful'. Please advise on why the license is not being re-imported successfully and how to resolve this issue.
4.016+0000 [L: ERROR] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [P: ] [T: main] Unable to process capability response because Storage anchor break found.
2026-01-07 10:35:04.032+0000 [L: INFO] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: main] Unable to read trial license file. Attempting to load as Paid license
2026-01-07 10:35:04.079+0000 [L: ERROR] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: main] Storage anchor break found.
2026-01-07 10:35:04.079+0000 [L: ERROR] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: main] ====================================================================
2026-01-07 10:35:04.079+0000 [L: ERROR] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [P: ] [T: main] Valid license file missing. Expected location: D:\Program Files (x86)\ThingWorxFoundation\ThingworxPlatform
2026-01-07 10:35:04.079+0000 [L: ERROR] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [P: ] [T: main] Shutting down server..
2026-01-07 10:35:04.079+0000 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [P: ] [T: main] >>>>>>> PLATFORM SHUTDOWN START <<<<<<<<<
Rocko
(To:DS_14456119)
Hello @DS_14456119
It looks like you have a response from an expert. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
Hello @DS_14456119 ,
I am not sure what events took place that you are required to "re-import" the license file.
Can you provide the basic steps you followed and what step required you to re-import the license file.
Pehowe
