When is the callback updateProperty triggered for a customized widget ?
seanccc
Hi ,
For a customized widget, sometimes the callback function updateProperty is triggered as my expected, but sometimes not.
I found the following situations that updateProperty will NOT be triggered :
  1. afterRender is empty
  2. Div doesn't has nested div/span inside it . for example,  <div class="widget-content widget-helloWorld"><div class="DisplayText"></div></div> works,  but <div class="widget-content widget-helloWorld DisplayText"></div> doesn't work
  3. call this.setProperty function in afterRender won't be helpful in the above cases
I'm really confused about the behavior of triggering updateProperty , could someone give me a detailed description for updateProperty ?
=============afterRender====================
this.afterRender = function () {
   //this.setProperty("BarTitle", 'test');
   valueElem = this.jqElement.find(".DisplayText");
   valueElem.text(this.getProperty("BarTitle"));
Sean
slangley
(To:seanccc)
Hi @seanccc.
Here's what I found:
  • The updatePropery() method is called anytime a bound value for a widget property changes.
  • First, encode the updated property's value using the htmlEncode() method from the Encoder library.
  • Then, use thisWidget's setProperty() and getProperty() methods to update and access this new value.
    • This step is important as the getProperty() method will perform extra sanitization on the values being returned to the UI.
If you still have questions, please let us know.
Regards.
--Sharon
slangley
(To:seanccc)
Hi @seanccc.
Regards.
--Sharon
