I can create any branches without using Switch in ThingWorx Flow, it seems this approach covers the usage of Switch. I wonder in what kind of use case where using Switch is a must ?
Sean
Please check if you are able to see this page- https://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/index.html#page/ThingWorx/Help/Integration_Orchestration/DeveloperTools/Switch.html
Did you check this for usage and example ? - https://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/index.html#page/ThingWorx/Help/Integration_Orchestration/DeveloperTools/Switch.html/
Hi @seanccc
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
