When to use Switch in ThingWorx Flow ?
seanccc
I can create any branches without using Switch in ThingWorx Flow,   it seems this approach covers the usage of Switch.   I wonder in what kind of use case where using Switch is a must ?
Sean
1 ACCEPTED SOLUTION
mnarang
(To:seanccc)
mnarang
(To:seanccc)
seanccc
(To:mnarang)
@mnarang ,
The link  https://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/index.html#page/ThingWorx/Help/Integrati...
is a blank page.
Could you re-post the link ?  Thanks
Sean
mnarang
(To:seanccc)
slangley
23-Emerald II
(To:seanccc)
Hi @seanccc
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
