Where can I find the Thingworx.war file??
shariharan
I'm trying to run a local instance of the thingworx application on a windows machine and to do this, I'm following this guide: https://support.ptc.com/WCMS/files/169063/en/Installing_ThingWorx_6.6_1.pdf
I've installed all prerequisites including Thingworx 8.1. Please help me find the Thingworx.war file that has to be placed in the Tomcat installation location.
Thanks in advance.
Ram
jdass
(To:shariharan)
Hi Ram,
You can download any version of the ThingWorx  platform from the PTC Support site .
https://support.ptc.com/appserver/auth/it/esd/product.jsp?prodFamily=TWX
Once you download the appropriate version , you can find the Thinworx.war file by unzipping the downloaded package.
What version of ThingWorx are you trying to install? 6.6 or 8.1?
8 REPLIES 8
jdass
(To:shariharan)
Hi Ram,
Thank you for the reply. I was able to find almost all the required files and install it successfully. However, I'm unable to login to the local instance using the username and password given in the installation guide. None of the logs have any information except localhost_access_log which has nothing but status code 401.
The username I used: Administrator
Password: trUf6yuz2?_Gub
Is this something you could help with?
ytella
(To:shariharan)
Hi Sriram,
Could you please share application.log from ThingworxStorage/logs folder?
jdass
(To:shariharan)
Could you attach the Application logs present in ThingworxStorage/logs folder?
Here's a snippet of the file:
2017-10-06 14:16:34.376-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem ValueStreamProcessingSubsystem is starting
2017-10-06 14:16:34.376-0400 [L: INFO] [O: c.t.s.s.Subsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Starting Subsystem [ValueStreamProcessingSubsystem]
2017-10-06 14:16:34.376-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem ValueStreamProcessingSubsystem is started
2017-10-06 14:16:34.376-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem WSCommunicationsSubsystem is starting
2017-10-06 14:16:34.376-0400 [L: INFO] [O: c.t.s.s.Subsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Starting Subsystem [WSCommunicationsSubsystem]
2017-10-06 14:16:34.376-0400 [L: INFO] [O: c.t.c.p.m.DispatchingServerCommunicationModule] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Registering as EndpointBinding Registry Observer
2017-10-06 14:16:34.376-0400 [L: INFO] [O: c.t.c.c.m.CommunicationModuleBase] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Started DispatchingServerCommunicationModule [Running: true]
2017-10-06 14:16:34.376-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem WSCommunicationsSubsystem is started
2017-10-06 14:16:34.376-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem UserManagementSubsystem is starting
2017-10-06 14:16:34.376-0400 [L: INFO] [O: c.t.s.s.Subsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Starting Subsystem [UserManagementSubsystem]
2017-10-06 14:16:34.376-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem UserManagementSubsystem is started
2017-10-06 14:16:34.376-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem TunnelSubsystem is starting
2017-10-06 14:16:34.376-0400 [L: INFO] [O: c.t.s.s.Subsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Starting Subsystem [TunnelSubsystem]
2017-10-06 14:16:34.376-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem TunnelSubsystem is started
2017-10-06 14:16:34.376-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem MessageStoreSubsystem is starting
2017-10-06 14:16:34.376-0400 [L: INFO] [O: c.t.s.s.Subsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Starting Subsystem [MessageStoreSubsystem]
2017-10-06 14:16:34.376-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem MessageStoreSubsystem is started
2017-10-06 14:16:34.376-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem LicensingSubsystem is starting
2017-10-06 14:16:34.376-0400 [L: INFO] [O: c.t.s.s.Subsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Starting Subsystem [LicensingSubsystem]
2017-10-06 14:16:35.670-0400 [L: ERROR] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] License Server could not process request
2017-10-06 14:16:35.749-0400 [L: ERROR] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] License Server could not process request
2017-10-06 14:16:35.814-0400 [L: ERROR] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] License Server could not process request
2017-10-06 14:16:35.892-0400 [L: ERROR] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] License Server could not process request
2017-10-06 14:16:35.892-0400 [L: ERROR] [O: c.t.s.s.l.LicensingStateMachine] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Unable to fetch license file with device id b1c294ca-eaa7-401b-8f1e-b5d730abe775
2017-10-06 14:16:35.892-0400 [L: ERROR] [O: c.t.s.s.l.LicensingStateMachine] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Unable to connect to the PTC license server.  Please make sure the LicensingConnectionSettings settings in the platform-settings.json in the ThingworxPlatform directory are correct. If your server is not connected to the internet please use the request file licenseRequestFile.txt created in the ThinworxPlatform directory to do a manual install of the license
2017-10-06 14:16:35.892-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem LicensingSubsystem is started
2017-10-06 14:16:35.892-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem FederationSubsystem is starting
2017-10-06 14:16:35.892-0400 [L: INFO] [O: c.t.s.s.Subsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Starting Subsystem [FederationSubsystem]
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem FederationSubsystem is started
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem LoggingSubsystem is starting
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.s.Subsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Starting Subsystem [LoggingSubsystem]
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem LoggingSubsystem is started
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem AlertProcessingSubsystem is starting
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.s.Subsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Starting Subsystem [AlertProcessingSubsystem]
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.s.a.AlertProcessingSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Starting Alert Processor...
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem AlertProcessingSubsystem is started
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem ExtensionSubsystem is starting
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.s.Subsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Starting Subsystem [ExtensionSubsystem]
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem ExtensionSubsystem is started
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem ExportImportSubsystem is starting
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.s.Subsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Starting Subsystem [ExportImportSubsystem]
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem ExportImportSubsystem is started
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem IntegrationSubsystem is starting
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.s.Subsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Starting Subsystem [IntegrationSubsystem]
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem IntegrationSubsystem is started
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem PlatformSubsystem is starting
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.s.Subsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Starting Subsystem [PlatformSubsystem]
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem PlatformSubsystem is started
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem EventProcessingSubsystem is starting
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.s.Subsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Starting Subsystem [EventProcessingSubsystem]
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.s.e.EventProcessingSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Starting Event Router...
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem EventProcessingSubsystem is started
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem StreamProcessingSubsystem is starting
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.s.Subsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Starting Subsystem [StreamProcessingSubsystem]
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem StreamProcessingSubsystem is started
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem WSExecutionProcessingSubsystem is starting
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.s.Subsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Starting Subsystem [WSExecutionProcessingSubsystem]
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem WSExecutionProcessingSubsystem is started
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem FileTransferSubsystem is starting
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.s.Subsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Starting Subsystem [FileTransferSubsystem]
2017-10-06 14:16:35.907-0400 [L: INFO] [O: c.t.s.s.f.e.TransferTracker] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Creating new Transfer Tracker
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem FileTransferSubsystem is started
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Subsystem SCIMSubsystem autostart is off
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ========================================
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.s.m.MessageStoreSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] MessageStore Subsystem Settings
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.s.m.MessageStoreSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ----------------------------------------
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.s.m.MessageStoreSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Thread Pool Minimum Size = 10
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.s.m.MessageStoreSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Thread Pool Maximum Size = 100
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.s.m.MessageStoreSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Max Queue Size = 100
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.s.m.MessageStoreSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Max Thread Life = 600000
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.s.m.MessageStoreSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Max Message Count = 1000
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.s.w.WSExecutionProcessingSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] WSExecutionProcessing Subsystem Settings
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.s.w.WSExecutionProcessingSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ----------------------------------------
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.s.w.WSExecutionProcessingSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Thread Pool Minimum Size = 1000
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.s.w.WSExecutionProcessingSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Thread Pool Maximum Size = 10000
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.s.w.WSExecutionProcessingSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Max Queue Size = 100000
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.s.w.WSExecutionProcessingSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Max Thread Life = 600000
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] FileTransfer Subsystem Settings
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ----------------------------------------
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Thread Pool Minimum Size = 10
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Thread Pool Maximum Size = 10
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Max Queue Size = 100
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Max Thread Life = 600000
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] File Transfer Idle Timeout = 30000
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Max File Transfer Size = 100000000
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Max File Transfers Allowed in Offline Queue = 50000
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Max File Transfers Allowed Per Thing in Offline Queue = 10
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Time To Live (sec) of File Transfer in Offline Queue = 86400
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] FileTransfer Idle Timeout for Edge Controlled Transfers = 600000
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Max Concurrent Edge Controlled File Transfers Allowed = 500
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Max Concurrent Edge Controlled File Transfers Allowed Per Thing = 2
2017-10-06 14:16:35.923-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Starting All Things...
2017-10-06 14:16:35.954-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Activating Property Bindings...
2017-10-06 14:16:35.954-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Initializing Property Binding relationships...
2017-10-06 14:16:35.954-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Sending Post Start Notifications...
2017-10-06 14:16:35.986-0400 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Thingworx Server Application...ON
2017-10-06 14:16:36.001-0400 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Datastore database...INITIALIZED
2017-10-06 14:35:09.023-0400 [L: ERROR] [O: c.t.p.h.H2ModelExceptionTranslator] [I: ] [U: ] [S: ] [T: http-nio-8001-exec-4] [message: [1,012] Data store timeout error: [Error occurred while accessing the model provider.]]
2017-10-06 14:35:09.024-0400 [L: ERROR] [O: c.t.s.a.AuthenticationUtilities] [I: ] [U: ] [S: ] [T: http-nio-8001-exec-4] Failed to lock user
jdass
(To:shariharan)
Could you share your platform-settings.json file?
ytella
(To:jdass)
Also, please review the resolution steps given in the following document and let us know the result:
https://www.ptc.com/en/support/article?n=CS233225&language=en&posno=10&q=401%20error&source=search
jdass
(To:jdass)
From the Application log , this line "2017-10-06 14:16:35.892-0400 [L: ERROR] [O: c.t.s.s.l.LicensingStateMachine] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Unable to connect to the PTC license server.  Please make sure the LicensingConnectionSettings settings in the platform-settings.json in the ThingworxPlatform directory are correct. If your server is not connected to the internet please use the request file licenseRequestFile.txt created in the ThinworxPlatform directory to do a manual install of the license" --> states that the  LicensingConnectionSettings settings in the platform-settings.json is incorrect.
