Where to find the Advanced Grid Widget extension
isengineer
6-Contributor
Hi All,
Where can i download Advanced Grid Widget (Package Ver. 4.0.2)Extension please?
Many thanks in advance.
Koray
The Advanced Grids are available as standard widgets in the ThingWorx Platform for 8.5.X and later.
ThingWorx 8.4.X and earlier uses Advanced Grids that are available as extensions in the PTC Software Download page. There may not be an upgrade for these extensions in later releases. It is recommended to use the standard widgets in the ThingWorx Platform 8.5.X and later.
From "Help Center" - "Advanced Grids (Legacy)": http://support.ptc.com/help/thingworx/platform/r9/en/#page/ThingWorx/Help/Mashup_Builder/Widgets/AdvancedGrids.html
Article - "How to use the Advanced Grid Widgets in ThingWorx": https://www.ptc.com/en/support/article/CS318198
isengineer
6-Contributor
(To:VladimirN)
Hi VladimirN,
Thank you for your feedback. I have resolved my issues with advanced grid widget and i will mark this as accepted solution.
Kind regards
Koray
Glad you solved your problem.
