Why LocalizationToken doesn't work in widget "PropertyDisplay" ?
anthony1
7-Bedrock
My question is in the title. I would like to know why when I try to put a LocalizationToken on field of my property display widget I cannot have the result. However the token is ok on a label of the same mashup.
There is a bug or not ? Because it work fine also in grid.
Anthony
1 REPLY 1
paic
(To:anthony1)
If I am not mistaken, the property display widget derives the Field Names and Values from the data source.
Unlike a Grid, this widget doesn't receive a source with a specific datashape so you can't localize those in the mashup design.
So if you wanted to show that localized, you would have to create a custom service that localizes the data content being delivered to the mashup.
