Why widgets from mashups show error when im logging with another user
RG_8193694
6-Contributor
I am made an mashup which is connected with other mashups in a organization. When im logging with a user mading for tests, the mashup's widgets show this error.
I think is by the permissions, but i already added permissions for visibility and runtime for the user however it shows the error.
5 REPLIES 5
slangley
(To:RG_8193694)
Hi @RG_8193694
Do you still get the error when you test with the Administrator's account?
--Sharon
RG_8193694
6-Contributor
(To:slangley)
with the Administrator account the mashup works fine
slangley
(To:slangley)
Hi @RG_8193694.
Sounds like the issue is permissions-related.  You can possibly start with this article for assistance to troubleshoot the issue.
--Sharon
slangley
(To:slangley)
Hi @RG_8193694.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
gochoa
(To:RG_8193694)
I have the same problem
