Widget size is changing at runtime if change the resolution.
vi1
I am using the gauge widget in responsive mashup.
My widget size is changing if change the resolution.
How to fix the widget size constantly if change the resolution.
Please find the attached images.
Thank You.
vi1
(To:vxavier)
Thank you Vinícius for giving the response.
If I keep widget into panel, getting the scroll bars for each gauge.
Thank You.
3 REPLIES 3
vxavier
(To:vi1)
That is the concept of responsive, adjust the size by screen resolution. To keep the widget size, drag a panel to your responsive mashup, before drag your widgets.
You can create a totally static mashup also.
Cheers,
Vinícius.
vi1
(To:vxavier)
Thank You.
vxavier
(To:vi1)
That's with you. You have to think the best way to fit your data and widgets. Resizing, changing the layout, showing just relevant data...
