Below is my code:
//creating an infotable
let Log = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({
infoTableName: "InfoTable",
dataShapeName: "DataShape"
//Defining date variable
var currentDate;
//assigning valueList variable to my infoTable property that contains values (current it only has one row)
var valuesList = Things["TestThing1"].infoTableThingProperty;
//loop through the infotable above
for(var i=0; i<valuesList.length; i++){
// new object
newEntry = {
duration:valuesList[i].duration,
source: valuesList[i].Source,
Type: valuesList[i].Type,
StartTime: valuesList[i].StartTime,
EndTime: valuesList[i].faultEndTime,
Voltage: valuesList[i].Voltage,
Text: valuesList[i].Text
//adding my object values to the infotable
Log.AddRow(newEntry);
//adding my infotable to the stream
var newLog = Things["SinkWorx.PwrSupplyError_Stream"].AddStreamEntries({
values: Log /* INFOTABLE {"dataShape":"StreamEntryWithValues"} */
//output result
let result = Log;
I keep getting the error above, I am not sure why.
Does anyone know how I can fix it?
Kind Regards,
TB
duration: valuesList[i].duration,
Any o these INTEGER/NUMBER values might by NULL.
Try only with STRING values and change accordingly
try this..
let streamEntryData = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({
dataShapeName: "StreamEntryWithValues"
var currentDate;
for (var i = 0; i < valuesList.length; i++) {
// new object
newEntry = {
// StreamEntryWithValues entry object
let streamEntry = {
sourceType: undefined,// STRING
values: Log,// INFOTABLE
source: undefined,// STRING
tags: undefined,// TAGS
timestamp: new Date()// DATETIME
streamEntryData.AddRow(newEntry);
values: streamEntryData /* INFOTABLE {"dataShape":"StreamEntryWithValues"} */
//output result
let result = streamEntryData;
Hi @Sathishkumar_C thank you for the suggestion but I am still getting the same error.
Hi, thank you for the suggestion.
I found that the error was with the subscriptions calling the service.
So I removed the infotable property that I was loping through and instead used the built-in service: "queryStreamEntriesWithData" and wrote an actual query which I then passed to this built-in service.
Also the subscription I added some conditional statements that need to pass before calling the service.
This solved the issue.
Best Regards,
TB
To narrow down the source of the error, put everything in a try-catch clause and log the error object with the line number.
try {
// Your whole code here
} catch(err) {
logger.error(err.message + " in line " + err.lineNumber);
