X-axis format in Bar chart Thingworx 9.1
  • February 25, 2021
  • 2 replies
  • 1493 views
I am trying to display x-axis as DateTime but in my use case i need to show only time (hh:mm) at X-axis. there is property for Y-axis format but not for X-axis. how to do it in Bar chart ?
Best answer by suverma
Hi @VaibhavShinde
This is a limitation in 9.x Chart Widget(Bar, Line) but good news is this feature has already been reported as an enhancement and should be available in next release i.e. 9.2.0
I can update on this thread when the release is out but for now workaround is to send the x-axis data in required format from the service itself which feeds your Chart.
You can follow this post to modify your Date format: Change the date time format
suverma14-AlexandriteAnswer
Hi @VaibhavShinde
Community Manager
March 11, 2021
Hi @VaibhavShinde.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
