add json data to infotable
LL_10926685
Hi! i have read alot of documentation but cant find how to do this in TW9.5 i get succes on everything but it just adds empty lines in my infotable. i have added the json and service below
{"station":"station_3","Artikelnr":2053,"antal":46,"vo":767,"Embalage":"Packaging_3","operator":"Operator_4","Antalskort":3}
var dataTableName = "Proddata";
var dataShapeName = ".datashape.lucas";
var result = "Success";
try {
    var dataToAdd = dataToAdd;
    var jsonData = JSON.parse(dataToAdd);
    logger.debug("Incoming JSON data: " + jsonData);
    // Directly access the InfoTable property on the Thing
    var infoTable = me[dataTableName];
    // Directly create a ValueCollection from the JSON data
    var rowValues = new Object();
    rowValues.station = jsonData.station;
    rowValues.Artikelnr = jsonData.Artikelnr;
    rowValues.antal = jsonData.antal;
    rowValues.vo = jsonData.vo;
    rowValues.Embalage = jsonData.Embalage;
    rowValues.operator = jsonData.operator;
    rowValues.Antalskort = jsonData.Antalskort;
    logger.debug("Row values created: " + JSON.stringify(rowValues));
//	var stringifyRowValues = JSON.stringify(rowValues);
    logger.debug('RowValues to use' + (rowValues) );
    // Add the row to the existing InfoTable
    infoTable.AddRow({
        row: rowValues
    logger.info("Data added to InfoTable successfully!");
} catch (err) {
    logger.error("Error processing data: " + err.message);
    result = "Error: " + err.message;
result;
Hi @LL_10926685 ,
Kindly find this below code it may helps you. If any queries kindly do let me know.
try {
    // Assuming dataToAdd is coming from somewhere within the code or an input
    logger.debug("Incoming JSON data: " + JSON.stringify(jsonData));
    // Create a new row object to match the expected structure of the InfoTable
    var rowValues = {
        station: jsonData.station,
        Artikelnr: jsonData.Artikelnr,
        antal: jsonData.antal,
        vo: jsonData.vo,
        Embalage: jsonData.Embalage,
        operator: jsonData.operator,
        Antalskort: jsonData.Antalskort
    infoTable.AddRow(rowValues);
} catch (err) {
result;
Thanks & Regards,
Arun C
1 REPLY 1
Hi @LL_10926685 ,
try {
    var rowValues = {
        vo: jsonData.vo,
} catch (err) {
result;
Thanks & Regards,
Arun C
