analytics dataset error
JackEom
I'm practicing by installing an Thingworx anaytics in developer build a predictive analytics model.
Error occurs. data set stops everytime.
Please refer to the attached picture
1 ACCEPTED SOLUTION
cmorfin
(To:JackEom)
Hi @JackEom
Can you check if the twas-zookeper service is started, if not check https://www.ptc.com/en/support/article/CS285428 to correct.
If it is, then execute the TWALogCollector (https://www.ptc.com/en/support/article?n=CS316782) and upload the zip file created.
Christophe
2 REPLIES 2
cmorfin
(To:JackEom)
Hi @JackEom
Christophe
slangley
23-Emerald II
(To:JackEom)
Hi @JackEom.
If the previous response allowed you to solve your issue, please mark it as the Accepted Solution for the benefit of others with the same issue.
--Sharon
