In slider widget, accuracy in selecting value is low. Any other widget available to select range or any extension available ?
We can achieve higher accurate value using slider widget
This can be achieved by step size = 0.01 and precision = 2
If more precision required increase step size like 0.001 and precision =3 so on.
Hope this Helps!!
Hi @AP_9587236 ,
I have not observed any accuracy issues in that widget, at least in ThingWorx 9.3.3
Could you please:
Hope this Helps!!
Between the range 0 and 2000, if i want to select min=200 and max = 600 means, it is difficult to select exact value.
Hi @AP_9587236.
If you're running 9.3, there's also a property called EditableValue which will allow you to enter the value in the box above the slider.
--Sharon
