audit_target does not work
htran-21
My logger setting in config file is
	"logger":	{
		"level":	"DEBUG",
		"audit_target":	"r:/_tw_logs/audit.log",
		"publish_directory":	"r:/_tw_logs/",
		"publish_level":	"DEBUG",
		"max_file_storage":	"20000000",
		"auto_flush":	true
The audit.log does not have the same content as wsems_log1.log while they have the same log level. Is there any way to configure 2 different log files for AUDIT and DEBUG level?
My Bests,
Hung Tran
Hello @htran-21 ,
There are only two log files - the EMS log file, which contains the same content as what's output to stdout, and the 'audit log', which only contains 'AUDIT' level log data and can be written to a file:// or http:// based URI (controlled by audit_target).  publish_level and publish_directory control  the main log file - if publish_level is different than level, then one level of log messages will be sent to stdout while another will be written to a file (so you could have info to stdout but trace to your log file).  The above json attributes are all on the logger parent in config.json.
Hello @htran-21 ,
slangley
(To:htran-21)
Hi @htran-21.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
