Session Variable Change Not Firing Event
jimh
Hi All,
I'm trying to fire an event when a session variable is changed, but nothing seems to happen.  I set up the variable and bound the changed event to a service, but when I update the session variable via a service, nothing happens.  I did confirm that the variable is being updated.  I'm using 8.5.3 and I found this:
https://www.ptc.com/en/support/article/CS290680?&language=en&posno=1&q=SetGlobalSession%20value%20se...
Which is the same issue I appear to be having.  I was just wondering if anyone else has noticed the same issue -- as I'm probably doing something wrong.
I'm trying to implement:
 https://www.ptc.com/en/support/article/CS314806?&language=en&posno=2&q=thingworx%20service%20session...
Option 1
Thanks!
1 ACCEPTED SOLUTION
jimh
(To:jimh)
This has somewhat been solved. I talked to a smart colleague who pointed me in a different direction. He suggested setting the variable via a mashup function and that seemed to do the trick!
Never could get the PTC example to work though.
5 REPLIES 5
jimh
(To:jimh)
slangley
23-Emerald II
(To:jimh)
Hi @jimh.
Glad you found a solution.  I will have someone look at the articles you referenced for needed updates.  They are both fairly old.
Regards.
--Sharon
slangley
23-Emerald II
(To:slangley)
Hi @jimh.
One other thing, could you please mark your post containing the solution as the Accepted Solution for the benefit of others with the same question?
Regards.
--Sharon
jimh
(To:slangley)
Hi @slangley
There isn't a post as we chatted on the phone.  But, the gist of it is:
Instead of updating the session variable through the service, updated it through the actual mashup using a function.  So when I want to update the contained mashup, I also fire the mashup function that sends its output to the session variable via the function -- if that makes sense.
slangley
23-Emerald II
(To:slangley)
Hi @jimh.
I have marked one of your posts as the solution.  If you disagree with my choice, please let me know.
Regards.
--Sharon
