base64 to blob via base64DecodeBytes gives error
oskarberntorp
I have a service that I am utilizing to save files, I have a remote thing written in C# calling it.
Among the fileName and type, I also have the fileData as a parameter of type string, this string is a base64Encdoded blob (byte array).
When I run the base64Encoded byte array througth base64DecodeBytes, I get this error:
 JavaException: java.lang.Exception: Unable To Convert From org.json.JSONObject to BLOB
Basically, I am doing something wrong, how do I decode a base64 string into it's underlying byte array so it can be saved with saveBinary? What I think is odd is that the error talkes about a json object, when the FileData parameter is a text type and is a base64 string,
When trying to send the byte array as a string in the json request and sending the file into the saveBinare function, I get this error: JavaException: java.lang.Exception: Invalid length
Kindly
Oskar Berntorp
Rocko
(To:oskarberntorp)
I think for PDFs base64 it not the best option, as PDFs are rather large objects and base64 is not an efficient coding. I'd rather try to use a protocol supporting binary data to transmit PDFs for efficiency.
In your case, I wonder where the problem is, if it is base64 and you can decode it, it shouldn't matter if it is an image or a PDF or any other binary format. Here's some sample code to encode and restore:
Encode to base64:
function encodeBase64(repo, path) {
    let s = repo.LoadBinary({path:path});
    var blobArray = [];
    logger.warn("s.length="+s.length);
	for (var i = 0; i < s.length; i++)
        blobArray.push(s[i]);
    b64=base64EncodeBytes({"array":blobArray});
    repo.SaveText({	path: path+".b64", content: b64});
    return b64;
result=encodeBase64(Things["SystemRepository"],"thumbnail.png");
Restore binary from b64 String:
function restoreBase64(repo, path) {
    let b64 = repo.LoadText({path:path});
    repo.SaveBinary({ path: "decoded-"+path.slice(0,-4), content:b64});
    return b64;
result=restoreBase64(Things["SystemRepository"],"thumbnail.png.b64");
if it's PNG or PDF shouldn't matter.
3 REPLIES 3
Rocko
(To:oskarberntorp)
Have you checked the base64 string is valid by pasting it into a different converter? Does it contain newlines?
Invalid length would indicate it didn't receive valid base64,
base64EncodeBytes takes a json parameter with field called array you will have to populate:
// base64EncodeBytes(value:JSON):STRING
let encodedValue = base64EncodeBytes(/* SampleInput={"array":[arrayOfBytes]} */);
oskarberntorp
(To:Rocko)
Hi @Rocko ,
I have now tested again, the base64 string could be decoded but then it does not seem to be correctly translated inte a pdf. Whet testing with base64 guru I had to use their tool base64 to pdf, it would be good if thingworx had something similar. Images can be converted from a base64 representation, why not pdfs?
Kindly
Oskar Berntorp
Rocko
(To:oskarberntorp)
Encode to base64:
    var blobArray = [];
    return b64;
    return b64;
