can a Node.js Socket server connect a ThingWorx
CHASEONHO
18-Opal
our customer need connect thingworx using TCP/IP
and i found TCPExtension guide
TCPThing looks like 1:1
but customer has many sensor or device than 1
they use BUboard to change Network(TCP/IP) to Serial(RS 485)
and socket server use Node.js
board use C socket client
we want to connect a ThingWorx without another protocol like MQTT
What should I do?
What should we prepare?
I'm thinking of using a software.
However, I hope that the information will be delivered to ThingWorks immediately at no additional cost.
Thank you.
CRArko
(To:CHASEONHO)
Hello, Seonho Cha.
I found a case which asked about a similar situation; unfortunately the result indicates that  MQTT may indeed be necessary.
For some additional information you could also take a look at the post:
Drag and Drop Edge Device Development with ThingWorx, Node.js and Node Red
-- Craig A.
2 REPLIES 2
CRArko
(To:CHASEONHO)
Hello, Seonho Cha.
-- Craig A.
Thank you!
i wonder is Node.js same a Node Red?
