hi, can i define a map object in thingworx,
I used new Map() in sevices but it does not work
Hello @chenzhuang111 ,
You can create map object by following the below link.
https://www.ptc.com/en/support/article/cs305450
Kindly let me know if you have anything further.
Bhawna
Bhawna
