I am trying to connect azure Iot hub to thingworx platform using this link:
https://developer.thingworx.com/en/resources/guides/azure-iot-hub-connector-quickstart
1. This tutorial is given with java code. I want to use .net to start connection server with thingworx platform. How do I do this?
2. Also, I tried to start connection server but getting following error:
Caused by: com.typesafe.config.ConfigException$IO: C:\Thingworx-Azure-IoT-Hub-Connector-2.0.0.141\connector\conf\azure-iot.conf-Dlogback.configurationFile=C:\Thingworx-Azure-IoT-Hub-Connector-2.0.0.141\connector\conf\logback.xml: java.io.FileNotFoundException: C:\Thingworx-Azure-IoT-Hub-Connector-2.0.0.141\connector\conf\azure-iot.conf-Dlogback.configurationFile=C:\Thingworx-Azure-IoT-Hub-Connector-2.0.0.141\connector\conf\logback.xml (The filename, directory name, or volume label syntax is incorrect)
Please provide your guidance.
Hello @Mayur_Phase,
For your error -- just add a space between "conf" and "-D", so that it reads like that:
...connector\conf\azure-iot.conf -Dlogback.configurationFile...
/ Constantine
There are no errors in your example, only warnings. You can probably ignore those, as soon as it works.
/ Constantine
Thank you for your response.
As these are warnings, I checked for connection server that should get started after running azure-iot.bat command but unable see any connection server that is started here. (followed path to check server connection: thingworx foundation⇾monitoring⇾connection servers).
Please have a look.
Hi @Mayur_Phase.
Please advise the version of ThingWorx you are running. If you're running ThingWorx 8.5+, you'll need to update to the latest version of the ThingWorx Azure IoT Hub Connector:
If you're running a version of ThingWorx prior to 8.5, please check your settings for something that may have been missed.
--Sharon
Hi @Mayur_Phase.
If one of the previous responses allowed you to find a solution, please mark the appropriate one as the Accepted Solution for the benefit of others on the community.
--Sharon
Hi @Mayur_Phase.
Are you continuing to struggle to find a solution to your connectivity issue? If so, please provide updated information so we can assist.
--Sharon
Thank you.I was working on iot hub connector 8.5. Yes Sure I will check again the connection setting as per your suggestion
