containsLocation Function throws error
plaban
6-Contributor
I am getting  error while using containsLocation function.
Service with
2 inputs
CurrentLocation (Type: Location)
Geofence(Type: InfoTable, DataShape: GeoFenceBoundaryDataShape).
Script  of service
// location:LOCATION
var location = CurrentLocation;
// geoFence:INFOTABLE
var geoFence = Geofence;
// containsLocation(location:LOCATION,geoFence:INFOTABLE,locationField:STRING):NUMBER
var result = containsLocation(location, geoFence,"");
This script throws below error when I was testing it.
Error executing service
Wrapped java.lang.Exception: Unable To Convert From com.thingworx.dsl.engine.adapters.ThingworxInfoTableAdapter to INFOTABLE Cause: Unable To Convert From com.thingworx.dsl.engine.adapters.ThingworxInfoTableAdapter to INFOTABLE
GeoFenceBoundaryDataShape: Data shape having one Location type column.
Please help!
Thanks & Regards,
Plaban
paic
(To:plaban)
Hi Plaban, the service is missing one more piece of information. The third parameter which you left blank, indicates the Name of the column in the geoFence table that contains the geo-coordinates.
