convert data into number in datatable
xiaoqw
here is my coding which I want to do calculation using datatable data. output should be "NUMBER". but now result is NaN. Could someone help me figure it out?
var query =
"filters": {
"type": "And",
"filters": [
"type": "EQ",
"fieldName": "Department",
"value": "Milk"
"type": "EQ",
"fieldName": "Kategory",
"value": "Production Volume"
var output = Resources["InfoTableFunctions"].RenameField({
t: Resources["InfoTableFunctions"].Aggregate({
t: me.QueryDataTableEntries({ maxItems: undefined,
query: query,
values:undefined,
source: undefined,
tags:undefined
columns: 'value',
aggregates: 'SUM',
groupByColumns: 'value'
to: "value"
var result = parseInt(output/10000);
1 ACCEPTED SOLUTION
PaiChung
22-Sapphire I
(To:xiaoqw)
It looks like you are trying to divide the whole infotable? maybe
var result = parseInt(output.value/10000);
 BTW it seems redundant to rename the field, not sure if you are trying to use the infotable somewhere else as well.
5 REPLIES 5
PaiChung
22-Sapphire I
(To:xiaoqw)
xiaoqw
(To:PaiChung)
Thank you for your help. it works!!!
tmisner
(To:xiaoqw)
Hello Tracy,
Thank you for reaching out on the ThingWorx Developers Community.
I did some quick testing with the code provided and I believe you can achieve the desired results by changing the last line to the following:
When you call for output only the return is an Infotable. If you call for output.value you specifically get the single number from the value field.
Please let me know if this is helpful.
Tyler Misner
ThingWorx Technical Support Engineer
Looks like @PaiChung has already replied on this one.
xiaoqw
(To:tmisner)
Anyway thank you for you testing my code!! And thank you Thingworx Developers Community
