hello everyone
I want to create xml file on button click and write some content into this. which API do i need to used how to used it. could you please help me into this.
Thanks in advance
The FileRepository thing template has a service called SaveXML. The input is the path and the content.
For write and edit XML files, here is a post explaining it:
Here it is a example:
var languages = <languages type="dynamic"> <lang>JavaScript</lang> <lang>Python</lang> </languages>; var params = { path: "/theXml.xml" /* STRING */, content: languages /* XML */ }; // no return Things["RepositoryThing"].SaveXML(params);
Hope it helps =)
Hi @RockLala
Could you please confirm if your issue has been resolved. If yes, Please mark this post as accept as solution for the future reference, So that other can take benefit in case of same question.
Redards- Mohit Goel
