create infotable from loop
Darryl
Hi All
Please could I get some advise (probably fundamentals).
I have the following code that I would like to display and send an email of an infotable as the result. How do I go about this?
var CurrentTime = new Date();
var sourceData = ThingTemplates["MeterTemplate"].GetImplementingThingsWithData();
var tableLength = sourceData.rows.length;
for (var x = 0; x < tableLength - 1; x++) {
    var currentRow = sourceData.rows;
    var sendfrom = "";
    var source = currentRow.name;
        if(CurrentTime.getTime() - Things[source].lastMeasureTime > 86400000) {
       logger.warn("Alert: (" + Things[source].name + ") hasnt recorded data since (" + Things[source].lastMeasureTime + ") ");
2 REPLIES 2
Hi Darryl,
Can you tell us where the problem is? Are you receiving any errors? If so, where exactly?
Btw. I noticed standard looping issue in your code. It should look like this:
for(var x=0; x < tableLength; x++)
or
for(var x=0; x <= tableLength -1; x++)
Otherwise you will lose your last record, while iterating through infotable.
Adam
Hi Adam
My problem is that I am not sure how to output the iteration into an infotable, and then email that infotable.
I get the results I am looking for posted to my log, but want a displayed infotable as well as an email.
Any help?
