We are working to address an issue with subscription email notifications. In the meantime, be sure to check your favorite boards for new topics.
datatable aggregate by day
davidcor
I have a dataTable that has columns that I would like to aggregate by the date part of the timestamp field but I'm not sure how to accomplish this.
paic
(To:davidcor)
There are some JavaScript functions you can use to get the Date only from a Date/Time and then you can use the build in Aggregate service.
LaurentGermain
6-Contributor
(To:paic)
you can use this:
var params = {
    types: 'STRING' /* STRING */,
    t: events /* INFOTABLE */,
    columns: 'date' /* STRING */,
    expressions: 'timestamp.getUTCFullYear()+"/"+(timestamp.getMonth() + 1)+"/"+timestamp.getUTCDate() '/* STRING */
// result: INFOTABLE
var r = Resources["InfoTableFunctions"].DeriveFields(params);
pschmaltz
(To:paic)
A few quick hints for folks who may not have used the infotable Aggregate function.
  • the columns, aggregates, and groupByColumns parameters support comma separated list of values. BUT be sure to not include any white spaces along with those commas. (e.g. use groupByColumns: "name,Date", not groupByColumns: "name, Date"​).
  • If you specify aggregating on multiple columns, be sure to include multiple aggregate types too.
e.g. Use parameter entries like this:
  columns: "name,Date" /* STRING */,
aggregates: "COUNT,COUNT" /* STRING */,
because something like this does not assume you want to use 'COUNT' on both columns and instead will throw an array out of bounds error:
  aggregates: "COUNT" /* STRING */,
​Perhaps well known details to others, but I spent a while looking in the wrong direction today before I figured this out. Hope this save others similar frustration.
As an aside, using the 3 step process of (1) query your data, (2) derive a new field for 'Date', and (3) Aggregate seems to do the job well for getting daily totals to use on charts etc.
