debug that a subscription is linked to alert correctly
aelrouby
2-Explorer
i created a subscription to an alert (on the same object). the subscription is enabled.
i set the value of the property to the value that launch the alert
i checked that the alert was issued (from monitor > Alert History)
but the subscription code is never executed?
how can i debug this issue?
2 REPLIES 2
PaiChung
22-Sapphire I
(To:aelrouby)
Start by adding a logger statement to the Alert subscription.
abarki
(To:PaiChung)
Hi @aelrouby,
Were you able to move further with the reply from @PaiChung, if yes? then kindly mark his Post as Accepted Solution, this will benefit other community members.;o)
If you still face the issue, then kindly provide current state in this post.
Thank you.
Asia
