duplicated key in DataTable
cdu
When I call AddDataTableEntry or AddOrUpdateDataTableEntry very quickly, two data row with same key will be added.
How to settle it?
Both serialNumber and alarmType are primary key. I have test unique primary key, but same error.
Code:
var query = {
  "filters": {
    "type": "AND",
    "filters": [
        "fieldName": "serialNumber",
        "type": "EQ",
        "value": serialNumber
        "fieldName": "alarmType",
        "type": "EQ",
        "value": alarmType
var params = {
    query: query,
    maxItems: 1
var old_times = 0;
var cc = Things["AlarmTimesTable"].QueryDataTableEntries( params );
if ( cc !== undefined && cc.getRowCount() != 0 ) {
    old_times = cc.getRow(0).times;
    //var values = cc;//.getRow(0);
var values = Things["AlarmTimesTable"].CreateValues();
values.gateway = me.name;
values.updateTime = updateTime;
values.serialNumber = serialNumber;
values.alarmType = alarmType;
values.times = old_times + 1;
var params = {
    //source :  me.name,
    values : values,
Things["AlarmTimesTable"].AddOrUpdateDataTableEntry( params );
logger.error("out");
cdu
(To:cdu)
"very quickly" means two http request at same time
LaurentGermain
6-Contributor
(To:cdu)
i met the same issue, and the only way to fix it is to create a service that locate duplicate and suppress them.
Seems there is  a delay before a newly written entry can be read
Hi Laurent,
I noticed that 6.5 settle the issue, but the second http request will report error, i.e. one of data be dropped.
I think the better solution is multithreading-locking, and a delay after Add ( not Update ) like you said.
Do you know is there any mutex/critical_section/thread_lockig functions? or task queue for one thread ?
This issue should be resolved in the recent 6.0.4 and 6.5 releases.
When I had the issue in prior versions, I added this code to a script to de-sync any concurrent requests:
var jitter = 200 * Math.random();
var delayUntil = new Date().getTime() + jitter;
while(new Date().getTime() < delayUntil); // busy-wait
