error in java SDK package
ds-21
In java sdk, the package was not supported i attached the error in javajavasdk.png
dinesh s​ This is very basic of Java Programming.
You have to make the same Package structure as mentioned in class.
For Example , SteamThing.java class is in Default package.
Make another package structure inside source as com>Thingworx.sdk.steam.
There are other way to get rid of such small compile time errors , The one above is simplest to get make it work.
Thank
Ravi Upadhyay
Thank
Ravi Upadhyay
ds-21
(To:ds-21)
thank you Ravi Upadhyay
You are welcome Dinesh
