currently, i am using the following versions: Thingworx 8.2, Analytics Server 8.2, Thingpred 8.2, Analytics Extension 8.2
When I try to trigger an analytics event-starting an Analysis Job- by changing the the Thing value of a previously to an analytics event connected Thing. Nothing happens besides this Error:
Job not found for update: dfcb4f20-2a88-493a-a0e6-76bc69196225 Dynamic deployment completion event is not dispatched |
What could be the reason for this?
regards,
max
Hi @Max3
If the event is not triggered this could come from multiple reasons.
Some of them are listed at https://www.ptc.com/en/support/article?n=CS283280 .
Hope this helps
Kind regards
Christophe
Hi @Max3
Hope this helps
Kind regards
Christophe
