exchange data between mashup and widget
mmmi
1-Newbie
Hi i am new at thngworx. I am developing a widget that can take JSON input from mashup variables and print the same on HTML page.
I am working with ThingWorx Composer (Javascript).
1 ACCEPTED SOLUTION
PaiChung
22-Sapphire I
(To:mmmi)
3 REPLIES 3
PaiChung
22-Sapphire I
(To:mmmi)
Not quite sure what you need help with.
But if you are trying to create a Widget, you should take a look at the Thingworx extension guide documentation which outlines how to create a Widget as an extension.
mmmi
1-Newbie
(To:PaiChung)
Thanks for reply.
There are some point which i want to understand.
1) How to check, the list of services available in a widget.
2) How i can invoke any of the services available in widget.
3) Pushing JSON data to a service.
4) Getting JSON response return by service.
Basically, i am creating more than one widget where output of one widget can be used as input to other.
It will be helpful if you can share "Thingworx extension guide".
PaiChung
22-Sapphire I
(To:mmmi)
