exporting only the filtered data
svisveswaraiya
I wanted to export the data that I have binded to grid. But, I am filtering the grid data by passing input. Based on the input, the grid data will be filtered. So, If I filter by order number only those filtered data needs to be exported. How can I achieve this?
I am mentioning the service that I am binding to grid.
switch(String(input))
case "All":
var params = {
To: To /* DATETIME */
// result: INFOTABLE dataShape: "Navistar_RejectedOrder_DS"
sampleResult = me.Get_RejectedOrderAll(params);
break;
case "Part Number":
var params = {
To: To /* DATETIME */,
partNumber: partNumber /* STRING */
sampleResult = me.Get_RejectedOrder_partNumber(params);
break;
case "Job Number":
var params = {
jobNum: jobNumber /* STRING */
sampleResult = me.Get_RejectedOrder_JobNumber(params);
break;
case "Line Set":
var params = {
lineSet: lineSetNumber /* STRING */
sampleResult = me.Get_RejectedOrder_lineSet(params);
break;
if (input == null || input == "")
var params = {
if (From == null || From == "" || To == null || To == "")
sampleResult = me.Get_RejectedOrderNoFilter();
var result1 = sampleResult;
var params2 = {
t: result1/* INFOTABLE */,
query: query /* QUERY */
var result = Resources["InfoTableFunctions"].Query(params2);
Shalini V.
If you just want to export the data shown on the Grid, then you can:
1. enable the isEditable in Grid
2. Bind the EditedTable property from Grid to an DataExport widget
VladimirRosu
(To:zyuan1)
I believe this works even without using the EditedTable, if the filtering is done server-side.
So just binding the service result to a DataExport widget will work just fine.
slangley
(To:svisveswaraiya)
Hi @svisveswaraiya.
If one of the previous responses answered your question, please mark the appropriate one with the Accepted Solution for the benefit of others with the same question.
--Sharon
