I am using the extension CSV Parser. But when I am trying to read the excel file, I was able to, but it wasn't showing anything in the table after running the service.
Attaching the result and code with the name Empty Results.jpg and Code.jpg.
Thanks & regards,
Aditya
Can you check again by putting below values for following parameters and try?
columnMappings: undefined
fieldDelimiter: ","
Vibhuti
@adiku Are you seeing any errors in the logs?
Please refer these posts for more information
https://community.ptc.com/t5/ThingWorx-Developers/CSV-Parser-Help/m-p/503575#M2036
Also, have a look at this article
Vibhuti
Hi @adiku.
Please provide more details around your use case. Which version of ThingWorx are you running?
--Sharon
I am still facing issue.
fieldDelimiter: ","
Vibhuti
I just wanted to follow up with you to see if previous response was helpful for your question?
If so, please indicate the appropriate response as the Accepted Solution for the benefit of other Community members who have the same question. If you are still experiencing issues, please do let us know your questions or concerns.
Vibhuti
