I have a small issue with the fileupload widget which is occurring across a number of versions of Thingworx (8.2.4 & 8.2.8). The upload itself is working correctly but the 'No file chosen' property of the widget doesn't update when I select a file for uploading. As I say, the actual upload works fine and the file is uploaded to the correct location in the repository
does anyone else have this issue, and if so have you figured out a fix, work around?
K
I also noticed this recently.
Not quite sure if this will help, but try to go into edit mode and just add a description to the widget and then save the mashup and launch it.
How strange ... but it works ... thanks.
