fill null values with next not null value in infotable
effpt3
I have a infotable with some columns (timestamp, DT, TEMC, etc;) and values are some null and double.
I need to replace the null with previous value. If previous value is also null, then I need to replace with next not null value. Please help me out.
Find attachment for my infotable
PaiChung
22-Sapphire I
(To:effpt3)
Please keep in mind that null is different from undefined
You either just loop through it and check each value and replace it,
Or you could use derive fields to generate a new column
if they are null you can use the following in the expression
columnname ? columnname : "nullreplacementvalue"
 but that can't get you previous value unfortunately.
PaiChung
22-Sapphire I
(To:effpt3)
abarki
(To:effpt3)
Hi effpt3,
If PaiChung answered you question, kindly mark the post as accepted solution, this will benefit other community members.
Best,
abarki
