get all items and subItems of a Group using BrowseItems
AN_9685270
Hello evryone,
I want to browse all items and subItems of a group but when I use BrowseItems services the parameter filter doesn't work well.
so When I write that :
/ result: INFOTABLE dataShape: "IndustrialItems"
var result = Things["TestIndConnEnergyRum"].BrowseItems({
filter: "*" /* STRING */,
path: "RUM_P1_MAG_VENTE" /* STRING */
I get no result but when i Specify some channels i get data
thanks in advance
AN_9685270
(To:slangley)
Thank you @slangley for your reactivity,
I found a solution using just some for loops, to browse all tags from an industrial connection, using just 2 services ; browseGroups and BrowseItems,
please find this attached my solution
// this service is for browsing all tags of an industrial connection
//level 1 : Groups
//level 2 : SubGroups
//Level 3 : items or Tags
var IndustrialConnectionThingName ="YourIndustrialConnectionThingName";
//get Groups
var Groups = Things[IndustrialConnectionThingName].BrowseGroups({
    filter: undefined /* STRING */,
    path: undefined /* STRING */
var resGroups = [];
for (var x=0x <  Groups.rows.lengthx++){
    var row = Groups.rows[x];
    var hasAnySubGroups = row.HasAnySubGroups;
    var IsSystemGroup = row.IsSystemGroup;
    var HasNonSystemSubGroups = row.HasNonSystemSubGroups;
    if(!IsSystemGroup &&HasNonSystemSubGroups && hasAnySubGroups){
        var groupFullPath = row.FullPath ;
        resGroups.push(groupFullPath);
//Get SubGroups
var resSubGroups = [];
for (var i=0i < resGroups.lengthi++) {
    var resGroupsRow = resGroups[i];
    var SubGroups = Things[IndustrialConnectionThingName].BrowseGroups({
    path: resGroupsRow /* STRING */
    for (var j=0j < SubGroups.rows.lengthj++) {
        var SubGroupsRow = SubGroups.rows[j];
        var hasAnySubGroups = SubGroupsRow.HasAnySubGroups;
        var IsSystemGroup = SubGroupsRow.IsSystemGroup;
        var HasNonSystemSubGroups = SubGroupsRow.HasNonSystemSubGroups;
        if(!IsSystemGroup ){
            var SubGroupFullPath = SubGroupsRow.FullPath ;
            resSubGroups.push(SubGroupFullPath);
// Get Items === Tags
//var resItems  = [];
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(IndustrialItems)
var resItems = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({
    infoTableName : "InfoTable",
    dataShapeName : "IndustrialItems"
// iterate over resSubGroups to get items
for (var p=0p < resSubGroups.lengthp++) {
    var resSubGroupsRow = resSubGroups[p];
        // result: INFOTABLE dataShape: "IndustrialItems"
    var items = Things[IndustrialConnectionThingName].BrowseItems({
        path: resSubGroupsRow /* STRING */
    //iterate over items to find tags and push them in resItems
    for (var k=0k < items.rows.length;k++) {
        var itemsRow = items.rows[k];
        //var TagName = itemsRow.Source ;
        //resItems.push(TagName);
        resItems.AddRow(itemsRow);
//infotable : datashape : industrialitems
result = resItems;
slangley
(To:AN_9685270)
Hi @AN_9685270.
We found an internal case on this issue.  I have requested a status and will post additional information here as it becomes available.
--Sharon
slangley
(To:slangley)
Hi @AN_9685270.
After reviewing with R&D, we're not sure this is the same issue that was previously reported.  You indicated in your post "I get no result but when i Specify some channels i get data."
Per the information in the Help Center, providing the channel is a requirement.  Please refer to this page and let me know if I'm misunderstanding something.
--Sharon
slangley
(To:slangley)
Hi @AN_9685270.
Good job!  Since you found a solution, please mark your last response as the Accepted Solution for the benefit of others with the same issue.
--Sharon
AN_9685270
(To:slangley)
//level 1 : Groups
//get Groups
var resGroups = [];
//Get SubGroups
result = resItems;
