May I know how to get Value "23" based on Category "Outstanding PTPP" and pass value to another Datatable using for loop?
below snippet will help you out. first get the datatableentry by key
iterate that to get value
now create infotable structure according to other datatable
set values to infotable entry and use adddatatableentry
// result: INFOTABLE dataShape: ""
var result1 = me.GetDataTableEntryByKey({
key: "GMP" /* STRING */
var params = {
infoTableName : "InfoTable",
dataShapeName : "newOtherDS"
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(newOtherDS)
var result2 = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
var tableLength = result1.rows.length;
for (var x=0; x < tableLength; x++) {
var row = result1.rows[x];
var value = row.value; // NUMBER
// newOtherDS entry object
var newEntry = new Object();
newEntry.name = "new entry"; // STRING
newEntry.value = value; // NUMBER [Primary Key]
result2.AddRow(newEntry);
// id: STRING
var id = Things["otherDataTable"].AddDataTableEntry({
sourceType: undefined /* STRING */,
values: result2 /* INFOTABLE */,
source: undefined /* STRING */,
tags: undefined /* TAGS */
// communityDS entry object
var params = {
// id: STRING
