hello,
am-21
hello,
hello,
     I have a query does thingworx support webcomponents in developing extensions.
supandey
(To:am-21)
Hi Aarthi, could you please elaborate which web components specifically you looking for? If you haven't already seen it, there's an Extension SDK available at ThingWorx Marketplace (https://marketplace.thingworx.com/Items/Extension%20SDK) together with Eclipse Plugin for ThingWorx Extensions (https://marketplace.thingworx.com/Items/eclipse-plugin-for-thingworx-extensions) to help you get started.
am-21
(To:supandey)
Hi Sushant, I am looking to add the polymer component in the ui, this needs importing the html files as dependencies.
So is thier a way to import html files in metadata.xml or elsewhere to do the same.
