hello,
I have a query does thingworx support webcomponents in developing extensions.
Hi Aarthi, could you please elaborate which web components specifically you looking for? If you haven't already seen it, there's an Extension SDK available at ThingWorx Marketplace (https://marketplace.thingworx.com/Items/Extension%20SDK) together with Eclipse Plugin for ThingWorx Extensions (https://marketplace.thingworx.com/Items/eclipse-plugin-for-thingworx-extensions) to help you get started.
Hi Sushant, I am looking to add the polymer component in the ui, this needs importing the html files as dependencies.
So is thier a way to import html files in metadata.xml or elsewhere to do the same.
