how do we give Column header separator line in TWX 9.1 ?
  • February 15, 2021
  • 1862 views
Hi ,
How to give column header separator line as in below image.
Best answer by yanchen
Hi @VS_9760165 ,
Please use below CSS for your requirement, this works for advanced grid:
.MyAdvancedGrid5 .widget-gridadvanced .xhdr td:not(:first-child)
border-left:2px solid red !important;
Modify CustomClass property of advanced grid as MyAdvancedGrid5 to apply the CSS
It should display something like below:
When a style theme is applied to the grid the header dividers disappear. On my local instance I unchecked grid property 'UseTheme' and used style definitions instead then I was able to show the header dividers. You can give it a try and see it fulfills your requirement.
Hi @SachinSharma ,
I must have to use Style Theme and also i want Column header separator line. can we do it using css?
yanchen15-MoonstoneAnswer
Hi @VS_9760165 ,
