how do we give Column header separator line in TWX 9.1 ?
VS_9760165
Hi ,
How to give column header separator line as in below image.
yanchen
(To:VS_9760165)
Hi @VS_9760165 ,
Please use below CSS for your requirement, this works for advanced grid:
.MyAdvancedGrid5 .widget-gridadvanced .xhdr td:not(:first-child)
border-left:2px solid red !important;
Modify CustomClass property of advanced grid as MyAdvancedGrid5 to apply the CSS
It should display something like below:
4 REPLIES 4
When a style theme is applied to the grid the header dividers disappear. On my local instance I unchecked grid property 'UseTheme' and used style definitions instead then I was able to show the header dividers. You can give it a try and see it fulfills your requirement.
Hi @SachinSharma ,
I must have to use Style Theme and also i want Column header separator line. can we do it using css?
You can try CSS. I am not yet sure what CSS would be, I will check on my instance and if I am able make it work, I will post it here.
yanchen
(To:VS_9760165)
Hi @VS_9760165 ,
