how i show dropdown after selecting another dropdown list?
Ru
want to show dropdown after clicking another dropdown's list. if i have 1st dropdown which having list as member and staff after selecting member or staff, i want to show 2nd new dropdown.
slangley
(To:Ru)
Hi @Ru.
Can you provide details of your use case?  If you can provide a mock-up that shows what you need step-by-step, it would be helpful.
--Sharon
Ru
(To:slangley)
want to show dropdown after cliking another dropdown's list.
if i have one dropdown named as 'User Type'. In this dropdown there are two filds which are 'members' and 'staff'. If i select 'member' then it will show second dropdown named as 'Band'. And if i select 'staff' then it will show third dropdown name as 'program ID'. Pleasse refer below attachment.
slangley
(To:slangley)
Hi @122.
At a high level,you might be able to do this with an expression in mashup builder to evaluate the contents of the 1st drop-down and bind with a boolean value.  This value can then be used to control visibility of the other 2 drop-downs.
If you still have questions, we should probably open a case for this.
--Sharon
slangley
(To:slangley)
Hi @122.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
