how to collect data entries from three datatable
MA8731174
Hey Community, here i want data from three different datatables and i want to have all the entries in one infotable. How can i achieve it? i think i need to have here infotable and collect all the data there...
let data;
linesArray.forEach(line => {
    logger.info("QControl."+line.lineName+"-"+line.lineLocation+".DT");
    let thingName = "QControl."+line.lineName+"-"+line.lineLocation+".DT";
    let maxItems = Things[thingName].GetDataTableEntryCount();
    data = Things[thingName].GetDataTableEntries({
        maxItems: maxItems /* NUMBER */
Velkumar
(To:MA8731174)
Hi @MA8731174
Instead of iteration over each row of data. You can use below code merge multiple tables
function mergeTables(table1, table2) {
	let params = {
		t1: table1 /* INFOTABLE */ ,
		t2: table2 /* INFOTABLE */
	// result: INFOTABLE
	let mergedTable = Resources["InfoTableFunctions"].Union(params);
	return mergedTable;
function getTableData(dataTableName) {
	let dataTableData = Things[dataTableName].GetDataTableEntries({
	return dataTableData;
let tableNames = ["Table1", "Table2", "Table3"];
let result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({
	infoTableName: "InfoTable",
	dataShapeName: "DATASHAPENAME"
tableNames.forEach((tableName) => {
	let tableData = getTableData(tableName);
	result = mergeTables(result, tableData);
/VR
MA8731174
(To:MA8731174)
I am doing like this so first flateneing the entries and saving them into an infotable. I hope that it will not lower the performance. Or is there any better solution as compared to this one.
let CollectAllEntriesIntoTable = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({
    dataShapeName: "QControl.QualityData.DS"
let data;
    data.rows.forEach(entry=>{
    CollectAllEntriesIntoTable.AddRow(entry);
Velkumar
(To:MA8731174)
Hi @MA8731174
If all there datatable has same DataShape. You can use union function to merge it
let params = {
	t1: table1 /* INFOTABLE */,
let result = Resources["InfoTableFunctions"].Union(params);
/VR
MA8731174
(To:Velkumar)
Thanks @Velkumar ..They have all the same datashapes but i have total 7 datatables and may be they will grow in future so the approached you have mentioned would not bad but does not fit here. Thats why i am now iterating each entry to store it in an infotable.
Velkumar
(To:MA8731174)
Hi @MA8731174
	let params = {
	return mergedTable;
/VR
