i have created a thing with javascript in the snipert service CreateThing ,but then i want to set the thing just created Propertis ,the thing create success,but the properties created failed.there is nothing error shown in Application ,this my script
You need a restart after the EnableThing and before setting the property:
Things[thingName].RestartThing();
Also you need to create the Thing with the prepared parameters ( before (EnableThing) ):
Resources["EntityServices"].CreateThing(params);
can not set Properties success too
thank you so much ,your answer solve my problem perfectly!
