Hello friends,
I'm using the free version of thingworx 8.5 for now, for learning purposes.
would like your help to find out if it is possible to create monitoring alerts
example:
if one of the devices drops its value to 1 open a message / alert saying "low level" and when that value increases it disappears.
thank you in advance for your attention.
att Marcus.
Hi @Marcus_Konflanz.
Check this page from the ThingWorx Help Center for learning more regarding alerts and subscriptions. Here's a guide from our dev portal that may also be helpful.
--Sharon
--Sharon
thanks for the help, it was very helpful.
