I am using thingWorx Utilities 8.0. Any sample or use case to create workflow
Jallipalli Nagaraju: Please refer and follow the Help center link for an example to create workflow along with necessary details.
-Durgesh
-Durgesh
Thanks Durgesh.
Hi Durgesh,
Unfortunately Demo related items are not installed while installing the ThingWorx utilities. Is there any other use cases includes user task and gateways?.
- Nagaraju jallipalli
Jallipalli Nagaraju: You can have the demo data by downloading & importing ThingWorx Utilities demo data from PTC Support Download Page.
I believe that is the only samples we have at this moment or atleast which I am aware off.
-Durgesh
Hi Durgesh,
Thanks for your reply. I made the workflow using Workflow Builder which include the Service Task, Receive Task items an executed successfully. I made it successfully by referring the article. Article Viewer | PTC. But I want to make workflow which include the User Task and Gateway. Can you please let me in case of any article it covered the Gateway,UserTask.
Appreciate your help.
Nagaraju jallipalli
