how to display the hierarchical data in form of tree in mashup as shown in the image.
Hi @achitters you can use Grid Advanced Widget from ThingWorx Marketplace. It contains both Grid&Tree widget allowing you to display such a hierarchy. Additionally there's a sample entity within the zip that you'll download named GridAdvancedExampleEntities-v3.0.xml this will create some demo mashups and things with services to return demo data something the attached screenshot
Thingworx has a structure called Networks which creates that hierarchy and can be easily visualized in the Tree widget in a mashup.
What it depends on is a table that has to and from or child and parent relationships.
for example
child | parent
A |
1 | A
2 | A
B |
3 | B
4 | B
This would give you two root nodes called A and B each with two children
The only requirement to be able to use a Network is that they all have to be Things, if that is not needed, you can create a DataTable instead. Make sure you have the Child and Parent field as primary in the DataShape.
i am a beginner in thingworx. I would like to understand how we can bring the data into Tree widget. Could you please explain in more detail? It will help me a lot. Thanks for your understanding.
