how to export all the entities of thingworx in one file, which are tagged under one model tag?
psaxena
all the entities which are created under same model tag, how to export them all as a single file so that one application can be easily exported from one Thingworx instance to another
Hi
From Composer:
  • Import/Export > To File > "Select desired Model Tag" > Export ( you can export it either on Binary format or XML ).
Best Regards,
Hi
From Composer:
Best Regards,
